GoneCamping
May 21, 2015Explorer
May not have been clear about this. It is NOT my intention to use the regular 30 amp shore cord at all, or to modify it in any way. I'm talking about simply not using it all, and instead unplug the coach cord going to the generator (220v 3 prong with locking tab on the neutral prong) and hooking into campground shore power via that cord fitted with 220v/50A shore power plug (instead of the regular 30 amp shore cord). Feeding off the genset 220 line is the only way the coach isolators will allow BOTH A/C units to run at the same time.
Again, I'm not talking about modifying anything at all on the coach, just using the generator 220v power plug into shore source instead of generated source. Should work...
I've wired a number of houses and all have passed electrical inspection, so like I said, I'm not a novice at this.
38,782 PostsLatest Activity: Sep 01, 2026
