JimM68
May 21, 2015Explorer
If you run your 30 amp 115v camper on a 220 volt genset, you will smoke EVERY electrical product on board...
Guys, screwing this up can be a DISASTER!
A 220 volt connection is intended to have 3 wires, L1 L2 and ground.
Neutral is not provided, nor is it needed.
An RV 30 amp connection also has 3 wires. Hot, Neutral, and Ground.
Neutral carries current, ground never does. (this is what makes a GFCI work)
Most S&B type 220v devices, stoves and ovens, and a/c's, don't have a neutral wired, because they have no use for it.
Your RV has no use for 220v, in fact it is very allergic to it. ALL current flow is from hot to neutral, or in the case of a 50 amp RV, from either L1 or L2, to neutral.
Do some studying on those twist lock connectors... there are a zillion of them, with many different uses.
38,782 PostsLatest Activity: Sep 01, 2026
