tropical36
May 21, 2015Explorer II
GoneCamping wrote:
May not have been clear about this. It is NOT my intention to use the regular 30 amp shore cord at all, or to modify it in any way. I'm talking about simply not using it all, and instead unplug the coach cord going to the generator (220v 3 prong with locking tab on the neutral prong) and hooking into campground shore power via that cord fitted with 220v/50A shore power plug (instead of the regular 30 amp shore cord). Feeding off the genset 220 line is the only way the coach isolators will allow BOTH A/C units to run at the same time.
Again, I'm not talking about modifying anything at all on the coach, just using the generator 220v power plug into shore source instead of generated source. Should work...
I've wired a number of houses and all have passed electrical inspection, so like I said, I'm not a novice at this.
Really trying hard to make some sense of what you're talking about and most sure other's are, as well.
First bit of confusion is with your reference to a 220vac 3 wire genset output and don't know of any 30amp coach with a 220vac onboard generator. There is no 220v present anywhere on a 30amp coach, with the genset or otherwise.
Then you say that you're not going to use the cord, but unplug it from the genset and then re-plug it into the pedestal. If the cord is plugged into the genset outlet like it would be for a coach without a transfer switch, then this cord is the shore power feed and yes, you can use a 50/30 amp converter cord for feeding from a 220vac 50amp service outlet. This conversion, doesn't allow for any 220v to enter the coach. However, you are still running everything on a 120vac 30amp circuit with this method.
Keep in mind that the genset has a 20amp breaker that only feeds the rear ac via a relay and one that is bypassed when on shore power, so the rear ac breaker in the coach main box is now feeding the rear ac, rather than the breaker on the genset.
38,782 PostsLatest Activity: Sep 01, 2026
