wildmanbaker
May 23, 2015Explorer
GoneCamping wrote:If you run your 30 amp 115v camper on a 220 volt genset, you will smoke EVERY electrical product on board...
HUH? You telling me the Onan Genset that is onboard my RV will smoke everything? Tell ya what, if my factory installed generator will smoke everything, then it should have already done that 15 years ago.
Thanks for the help guys...
No, what I believe he is saying is that no RV generator produces 220 volts. Your entire RV runs on 120 volts. Even 50 amp Rvs run on 120 volts. Their have been persons on this forum that have supplied their RV with 220 volts by mistake, and cooked everything that was hooked up at the time. They are really trying to help you.
38,782 PostsLatest Activity: Sep 01, 2026
