Rick_Jay
May 23, 2015Explorer II
wildmanbaker wrote:
No, what I believe he is saying is that no RV generator produces 220 volts.
Just to be accurate here (and admittedly picking some nits :) ), there ARE some RV generators which produce 240VAC, but they are usually on high-end DPs and are 12 kW and above. Some of the high end rigs require 240 VAC for their appliances to work.
GoneCamping, your RV generator as equipped from the factory is 120VAC, NOT 240VAC. Don't let the dual breakers fool you.
~Rick
38,782 PostsLatest Activity: Sep 01, 2026
