funbiz4all
Oct 06, 2017Explorer
3 way fridge
we have a 2005 itasca sunrise 38j class A. when we are driving 4-6 hrs should we put the fridge on aux,ac,or propane? should we run it off battery,or run the generator while drivjing, or have the prop...
dougrainer wrote:steveh27 wrote:
My 1997 Class B has a 3 way Dometic fridge. It does not have an auto setting. I drive with it on 12 volt. It can't run on 12 volt with the engine off, therefore no battery drain. I switch to propane when stopped. I don't like having the main valve open on the propane tank because if I got in an accident the lines would have free flowing gas to explode. If you don't get in accident nor stop to refuel you'll be OK.
Your Asme and DOT LP tanks have EXCESS FLOW VALVES. IF you have a major break in the LP system the tank flow shuts OFF. Whenever I hear people state concerns about the worry you have, I ask them to dig up any stories of a LP assisted catastrophe with an RV. They never can, just "things they have heard" Doug
