CA Traveler
I located the transfer switch, it's a IOTA ITS 50R. I tapped on it several times, with no results. It doesn't appear to be made to open easily, so I decided not to pry it open.
Everything that is 100 volt is working, I reduced my power cord to 100 and plugged it in the pedestal, the fridge, TV, lights, etc work, but nothing on the 30/50 side. There is nothing showing on the meter, as far as amps in use. The charging end and inverter seem to working off the 100 hook up.
Is there anyway for a novice to check to see if the transfer case is functioning?
