FeeLine wrote:
CA Traveler
I located the transfer switch, it's a IOTA ITS 50R. I tapped on it several times, with no results. It doesn't appear to be made to open easily, so I decided not to pry it open.
Everything that is 100 volt is working, I reduced my power cord to 100 and plugged it in the pedestal, the fridge, TV, lights, etc work, but nothing on the 30/50 side. There is nothing showing on the meter, as far as amps in use. The charging end and inverter seem to working off the 100 hook up.
Is there anyway for a novice to check to see if the transfer case is functioning?
From this post, it is obvious that you have no idea about 120 versus 12 volt and such. The "30/50" IS THE 120 volt to the RV. It is not a separate section. You have gone far enough and you need to get a Mobile Tech out at this point or take the unit in for service. You may hurt yourself if you try to go further. The fact as I asked, you have TV and refer operation points to 120 power to the RV unless your refer is on the Inverter side and you have the Inverter ON (inverting current). You need to respond to requests. Does your EMS panel have any lights or indication or is it DEAD? Doug
