New to RVing. On the subject of 30 & 50 amp... are they designed for specific size units??? EG...24ft versus 34 or A class units?? Can a 30 amp only be used in a 30 and a 50 in a 50? Trying to lea...
Anonymous
Not applicable
Jun 11, 2019
Small RVs generally come with 30 amp since most are entry level and only have one AC. However, it's not unusual to find larger entry level RVs with 30 amp service. The main reason to have 50 amp is the ability to run 2 AC units at the same time when hooked to shore power.
You can use a 30 amp RV on a 50 amp pedestal using an adapter or vice versa. Generally, you will not be able to run both ACs on a 50 amp caoch hooked to 30 amp service.
