Metaphor_7182ExplorerMay 21, 201430 amp =The RT electrical is 30 amps. So plugging it in to the 110V at the house it is pulling how many watts with nothing pulled from the house electrical to the vehicle (microwave, clock, radio, etc.)? :) ...Show More
NORM_WADDELLExplorerMay 21, 2014Power in WATTS is Voltage times Amperes.If you simply plug in, and do not turn on any loads, youare using 115 Volts times 0 Amperes = 0 WattsIf you add load, say 10 Amperes, you are drawing115 Volts times 10 Amperes = 1150 Watts = 1.15 KilowattsThis holds for a 30 Amperes rated circuit, but not for othertypes of circuits.
Related Content30 Amp VS 50 Amp30 amp / 50 amp30 vs 50 amp electrical issue help30 Amp Plug30 amps for 50 amp trailer
