zach477 wrote:
hanko wrote:
shut the breaker off to that AC, now that wasnt too hard was it
My panel just has one breaker labeled "AC".
dougrainer wrote:
Please state Year and model of your RV. I am not aware of ANY RV that auto turns on a 1st or 2nd AC without YOU telling it to do that. The ECC is just an auto control system to PREVENT running 2 AC's on 30 amp power. You just make sure that 2nd unit is turned OFF at the tstat. Doug
It's a 2008 Fleetwood Fiesta. My ECC absolutely does run two AC's just fine. It's doing it right now. It just keeps them from starting up at the same time, and if I turn on the microwave, it shed's one of them.
The only determining factor in whether one or both AC's come on is how hot it is inside the coach. If it thinks it needs both to cool it down, it runs both.
Not what I said. What I said was, the ECC will NOT auto turn on the 2nd AC. You8 still have a tstat as the last poster mentioned. You need to post brand of AC (I suspect RVP). Can you post a pic of the ECC and the AC wall tstat or is the ECC the tstat assbly for both the ECC and wall tstat? Doug
