dougrainer wrote:
The ECC requires NO 120 to operate its controls. The only line for the ECC to the breaker box is for the current sense at the breaker box. Sooo, the 20 amp Breaker labeled ECC goes direct to 1 AC unit and the other labeled AC goes to the other AC. Turn off each breaker 1 at a time to determine which breaker goes to which AC. My bet is the ECC breaker goes to the front AC. Doug
PS. the bottom pic you sent is for the 12 volt DC fuses.
Well I had a chance to try it out while plugged into a 15 amp breaker, and sure enough, the ECC breaker goes to the front AC.
Thanks Doug!
