debbiep63 wrote:
Just turning on the tv drops the volts from 118 intoI the red at 109
Ah ha! We can help with that ;)
With the tv on I would start by taking measurements at the pedestal and compare with the tv outlet to discover if the issue in the RV or at the pedestal.
Low voltage can be hard on some things so lets get this fixed.
If you are back home... give it a test there. If good at home then your first post was probably correct in that the campground supply was marginal. Reasonably common in older parks.
Many connect their RV with a power protection device that will cut power if voltage is out of spec, reverse polarity, bad ground and protects against minor power surges.
