This gave be an UH HUH! moment.
Hey there Thanks for your UH HUH moment The batteries are doing ok according to the voltage indicator? I will keep learning and BTW I usually print these threads so thanks again to all who contribute. Just cannot resist this morning adding a little "good old days" to this. What happened to simple? I used to love to go lite my little propane heater on my Toyota at least I could find it? ha when the grey water was full you knew because the shower would not drain. And if you wanted to read at nite you knew you were using up your battery so start the engine and recharge it, water pump out? no problem just lift up the dinette and unscrew it and replace it. So that's how old I am! lol Now I am online two computers running, gas heat for now and doing a load of laundry but Iam clueless for the most part....
