frankdamp
Apr 05, 2015Explorer
Your RV draws the amount of current it was designed for. If it's a 30A rig, that's its limit. If you're plugged into a 50A outlet through an adapter, the rig is still limited to 30A of service by its internal system limitations.
Consider voltage as "electrical pressure". If your system is limited to a certain flow rate (amps) because it was designed to work on 30 Amps, that's all it will consume. The "pressure" is not an issue. It can't force more electricity into your rig than it can consume.
