tropical36
May 23, 2014Explorer
craigspeer2001 wrote:
I have a 95 winebago brave and i upgraded the front ac from a 7500 watt too a 13,500 the generator will run both acs but when you plug into shore power with the same 30 amp plug you use on generator it want run both acs. I would like to keep it where the generator runs both units so what do i need todo correct the shore power deal or is it just what it is.
Best cure is to install a dual power adapter, so that you can run the rear ac on a separate circuit and usually the 20 amp pedestal outlet. This is what the genset does with it's 20 amp breaker and utilizing the 30 amp for the rest of the coach.
38,766 PostsLatest Activity: Jan 10, 2026
