phnguyk's avatar
phnguyk
30 to 50 amp conversion
Our 30 amp coach was prewired for a second ac. Recently installed one with a separate 20 amp cord to run to the pedestal. It worked, but was a bit of a pain. So this past weekend I upgraded our coach from 30 to 50 amp.
15' of 6/4 wire $48
Furion 50amp inlet $28
Square D 100 amp panel $20
50amp double pole $10
2x 20amp single pole $20
30 amp single pole $10
2' of 10/2 $28 for 25'
I ran the 6/4 to the cabinet next to my original 30amp panel and installed the Furion 50amp inlet in a new location outside. I wired the panel so that one 50 amp is dedicated to the 30amp breaker which then feeds my original auto transfer switch via 10/2. The other 50amp breaker now feeds my second ac and W/D through individual 20 amp breakers. I left the original 30amp panel and 12v distribution as is. The only draw back is my current generator wont power my second ac or W/D, until 1 I upgrade the generator and at that time upgrade the transfer switch and 30amp panel to a 50amp panel.
