I'm going to a camp site in Indio Ca.that has 30amp power.The post has two 30amp on it. One for my site and one for the site next to me. I bought a 30 to 30 to 50 amp Y spilter. I was told that if I p...
A true 50 amp RV service provides two 50 amp 120 volt circuits (12,000 watts total) with a common neutral. The 30-30 'Y' adapter will give you two 30 amp 120 volt circuits (7200 watts total). The full 50 amp service will also provide 240 volts across the two hot legs, while the 30-30 setup may or may not, depending on how the split service is wired.
