wildtoad
Nov 24, 2013Explorer II
What is the wattage of the heater? You say extension cord. What is the rating of the cord? If the heater is a typical 1,500 watt heater plus the fridge, plus the converter you will be using a good bit of power. Try a lower setting on the heater. You would be better off installing a dedicated 30 amp circuit for the MH.
The previous homeowner had wired a shed and I plugged a mh into it. Worked OK work a short time until it melted the wiring in the shed. You will be much happier (and safer) getting a 30 amp circuit installed.
38,782 PostsLatest Activity: Sep 19, 2026
