Matt_Colie
Nov 25, 2013Explorer II
Bill,
Your extension cord is not heavy duty enough and the plug was probably bad to begin with. If it was very hot, it may have damaged the receptacle it was plugged into.
Go get a heavy extension (if you are smart you will look for one with a light in the female end - saves a lot of grief) cord and try again. If you are in a normal household circuit. Do the math on everything you want to run and don't exceed the 15 amps (~1800 Watts) that the circuit is supposed to be able to handle.
Matt
Matt
38,782 PostsLatest Activity: Sep 19, 2026
