jsmart
Jun 01, 2015Explorer
30A vs 50A
Just a curious question for all you experts out there, We have a 2002 32V Itasca Sunrise, bought it used, have had it almost 2 years. It has the 30 amp power cord, however, the box the power cord goe...
kaydeejay wrote:cbr46 wrote:You weren't talking about 25A thru a 50amp cable. Your comment was "A 50A circuit is actually 2 120V lines so I would guess they are 25A each"
I don't mind being flamed when I put out bad info, but I fail to see how pushing 25A through a (now that I'm corrected) 50A circuit could result in DEATH (does caps make you any deader?).
Aren't you all glad I got the air cleared on this?
And just for grins, if 50A goes out on leg 1, and 50A goes out on leg 2, how much current returns on the common?
Best,
- bob
THAT was what was wrong.
Not dangerous in itself but it indicated a lack of understanding that COULD be dangerous to someone who did not appear to fully appreciate what is involved.
To answer your actual question - in a correctly configured split-phase 50A set up the neutral current is the DIFFERENCE between the two legs, hence if the two legs are at an equal draw the neutral current is zero.
