jsmart
Jun 01, 2015Explorer
30A vs 50A
Just a curious question for all you experts out there, We have a 2002 32V Itasca Sunrise, bought it used, have had it almost 2 years. It has the 30 amp power cord, however, the box the power cord goe...
John & Angela wrote:jerseyjim wrote:
EXODUSRV: Sure. I know what breakers are for....and if you trip them, something ain't right. Make all the adapters your want, jury rig all the wiring you want, but the bottom line is 30 amp does one a/c...and 50 does 2 a/cs' and one never has to worry about breakers or anything else.
And the KEY words (yours) to back me up is "dangerously warm". No need to get even CLOSE to that using 2 a/cs with 50 amps.
Just curious. Why would 30 amp not support two AC's. The total current is less than 30 amps. Nothing should get warm. I had a motorhome that had two AC's on 30 amps that had no problem, no warm cords. It used an EMS that insured that both AC's didn't start at the same time but they ran together (both compressors on) with no problems. Current readout was 24 to 26 amps. No jury rigging or adapters.
Our existing motorhome is 50 amp but we are often on 30 amp. Runs two AC's quite fine. EMS keeps everything under 30 regardless of what you turn on. (it does the power management of devices) Nothing ever gets warm.
What am I missing.
