meubank
Jun 19, 2014Explorer
360 Hp Cummins
I was wondering if anybody had an experience with a ISB-XT turbo diesel 6.7 liter, 360 hp @ 2600 rpm, 800 ft. lbs torque @ 1800 rpm My main concern is will it be enough pulling a 5600# Avalanche t...
dieselmaniac wrote:et2 wrote:eheading wrote:
What brand of RV are you looking at? It is extremely rare for a 40' motorhome of any price range to have the IXB-6.7 engine in it. A lot of them have the 360hp ISC engine in them that has 950 ft-lb of torque. Unless you are bothered by the slower hill climbing ability of this combination, in my opinion it would be more than adequate to meet your needs.
Ed Headington
I'm not so sure you're accurate. I think you meant ISB 6.7. Many motorhomes are (were) equipped with the ISB 6.7. 0ur 2013 Fleetwood Expedition has it in it - 360 hspwr & 800 lb-ft torque. It's almost 42' long. I believe the Discovery (2013) got the ISC 6.9 - 380 hspwr - 1200 lb-ft torque.
We've had no issues pulling a 4600 lb Jeep Liberty. It's rated to pull 10,000 lbs, I believe it will.
something rated for 10K does not always correlate to what motor the unit has. I have a 425ISC in my 40ft unit with a 50HP module add on
I pull a 3600lb toad and I barely have adaquite power on mountain passes.I would not ever want to own the same size unit such as your unit with a ISB 360HP.
