elcriollo1
Nov 01, 2013Explorer
38 ' gas chassis
Thinking about moving up to a 38' gas motorhome, probably a Winnebago Adventurer. Would like to hear from anyone who has a similar coach. Does it have sufficient power and how does it handle? Henry
WyoTraveler wrote:Also the coach should have 22.5" tires with Alcoa rims rather than 19.5"/steel rolling stock. Between the high ratio differential and larger diameter tires the power train will get you down the road just fine. The longer wheel base will have a bit wider turning radius.
Keep in mind when they jump up to the longer gas rig they put them on 26,000 lb chassis. The rear axle is 5.2 instead of 4.3 if I recall so you get more power than the lighter shorter chassis.
