I will be traveling the I-4 corridor from Tampa to Daytona, then I-95 up through Savannah. Does anyone know of a scale that will measure all 4 corners of my motor home along that route.
Quite often the CAT scales at truck stops have a level area right beside the scale with no guard rail. If so then drive on the scale with the right side tires OFF the scale on the apron are, and the front and rear axle on different platforms and get a weigh. Then pull the whole coach on the scale with front and rear axles on different platforms. Then do the math for your 4 corner weigh.
