gbopp
Jul 07, 2016Explorer
Get a new fuel filter for the generator. It probably needs changed. If not, at least you know when it was changed.
How is the oil level in the generator? If it's low, that could be the problem.
Also, another member had a similar problem a couple weeks ago. It turned out the low oil sensor was bad. He disconnected the sensor and the generator operated normally.
The sensor was then replaced.
It's something worth trying.
Let us know when you solve the problem.
38,782 PostsLatest Activity: Sep 10, 2026
