j-d
Jul 08, 2016Explorer II
Suggest you do this:
1. Let us know if you've been using or at least exercising this genset at least monthly. It takes shockingly little time for today's sorry gasoline to clog the tiny jets in the ONAN Micro series carburetors. (Adding stabilizer to the gas, every tankful, helps prevent a LOT of problems.)
2. Post Model and Spec Code. If it's a Micro, the Oil Sensor was discontinued pretty early in the Spec List. Not realizing that causes us to chase a gremlin that doesn't even exist.
3. Notify Moderator and ask to move this thread to Tech Issues. Better exposure to OP's who work on gensets.
The red cap
protects the threaded end that goes into the Micro's Fuel Pump. Lower left, inboard (toward centerline of coach) corner of the genset.
Micro is a single cylinder air cooled unit. Runs 3600 RPM, faster than your lawnmower at full throttle. Like a little B&S mower engine, it's splash lubricated. This means that oil has to be Fresh and Full. I emphasize Full because a couple years ago we had a rash of seized engines in these Micro's. They aren't a "bad" little machine, but they don't play well with Neglect. That's in both Fuel and Oil.
The red cap
protects the threaded end that goes into the Micro's Fuel Pump. Lower left, inboard (toward centerline of coach) corner of the genset.Micro is a single cylinder air cooled unit. Runs 3600 RPM, faster than your lawnmower at full throttle. Like a little B&S mower engine, it's splash lubricated. This means that oil has to be Fresh and Full. I emphasize Full because a couple years ago we had a rash of seized engines in these Micro's. They aren't a "bad" little machine, but they don't play well with Neglect. That's in both Fuel and Oil.
