Daveinet
Feb 21, 2014Explorer
Mike Hohnstein wrote:where do the GM Performance Crate motors come from? If they are sold as new, legally they have to be new. These also do not require a core, only the rebuilt ones want the old core.
No such thing as a NEW engine, only available in a NEW vehicle. BBC out of production for years, last version was the 8.1. I've had good luck with Goodwrench remans from GM dealers. Haven't use one since the bankruptcy however.
Any solution will be a rebuilt or remanufactured example. Not much good feed back from Jasper on line. What ever you do, pre-oil the engine thoroughly before attempting to start.
On Edit: If you are replacing your heads, it is well worth getting fast burn heads. This allows for higher compression and improved mileage. Its not just about performance - ie building a race engine. Fast burn is technology developed by a mutual partnership between Edelbrock and GM.
38,766 PostsLatest Activity: Jan 10, 2026
