randallb
Feb 24, 2014Explorer
Besides improper height of distributor and improper gear material another common cause of distributor gear failure in a BBC is a high volume oil pump. If you install a high volume pump on a BBC engine with standard clearances the load on the distributor gear increases dramatically and it will wear out prematurely. Also, explain the installation of a set of roller lifters and why it should be done while the intake is off. Aren't there other things that need to occur before roller lifters get installed?
Randy
Randy
38,766 PostsLatest Activity: Jan 10, 2026
