Bill_Diana's avatar
Bill_Diana
454 TBI Check Engine Light - uel Pump Relay
I‘m in need of advice, help, suggestions.......
1995 Chevrolet 454 TBI engine with about 66,000 miles.
Recently when starting the engine it will give up and then immediate shut down. Then it will be very difficult to restart. Lots of cranking before it starts. When it does start there is a Check Engine Light. The next time I start the engine it starts up just fine. After several starts and travelling for a while the check Engine Light will go out.
I found a procedure to short out the OBD terminals and got a Code 54 to flash on the dashboard.
It seems this hard start situation happens when on the road travelling and starting a hot engine. Several times I removed the battery cable to clear the check Engine Light and it seems the engine will then start right
up.
The engine has always started easily and this problem had just been the last few months.
Any ideas???
