jimsretirementf
Feb 29, 2016Explorer
Thank you for the information, looks like I have a lot to check. I know I can get a good fuel regulator from Summit Racing so I can check the pressure. I did pull the gas tank and put a new fuel pump and all gaskets in because it was leaking when it was filled up, no more oder of gas when filled up. I am not sure if the motor is starving after warmed up because I can smell a slight oder of gas after it starts, but the smell goes away right away.
Thank you for all the info.
