dodge_guy
May 28, 2015Explorer II
timmac wrote:dodge guy wrote:
All tuners from 5star have their custom tune. they do not sell tuners with a generic tune. so yes the tuner with just 1 tune is a custom tune for your particular RV. and yes it does work and is well worth the money. I got mine 3 years ago and after I got it I wish I would've gotten it much sooner!
No it will probably not pay for itself, but for how much it changes the transmission shift programming it makes driving much more relaxing.
You will not be disappointed.
What tune did you go with, they have three for 87 octane, economy, performance with tow/haul or performance with tow/haul OD lock out
I am leaning towards the performance with tow/haul since I tow 5000 lbs but will this reduce mpg or should I go with economy mode.
I went with the 3 tune option. 89 octane Economy, 89 towing and 89 performance. However my X with the V-10 doesn't have the 5speed with Tow/Haul. I bought mine primarily for the improved trans shift programming as the one Ford programmed it with left a lot to be desired even non towing! I did gain about .3 or so MPG only because the trans holds each gear longer letting the engine work in its power band instead of shifting early and then lugging back into the power band on the next shift. The tuner only adds about 20HP and about 20lbft TQ (not exactly sure on the numbers). Not a lot, but enough to notice when downshifting or accelerating. There is not enough to burn up a trans.
5star has an excellent reputation. And they are very easy to work with. Give mike a call if you have any real in depth questions!
38,778 PostsLatest Activity: Jun 07, 2026
