PNW_Steve
Jun 06, 2019Explorer
Timothy2001 wrote:Executive wrote:
Whoa Kimo Sabbe! It's a bit more complicated than simply replacing a breaker and receptacle. That is unless your home fire insurance is paid in full, you no longer like your house, and the insurance company won't find you at fault for frying all the wiring inside your box. Generally, 20amp service, (Tee shaped receptacle) uses 12 ga wire, 15amp service (Double I shaped receptacle) uses 14 ga wire. 50amp service uses a minimum of 10ga wire, depending on the length of the run. Simply changing out the breaker and receptacle will allow you to power up you A/C units for a bit as your breaker will not trip. However, your house wiring will then become a substitute for your breaker. Once the wiring gets too hot, it will melt and burn through if you're lucky. If you're not so lucky, it'll simply start a fire and burn your house down. Hire a licensed electrician....Dennis
LOVE THIS! I learned a long time ago what I am capable of, what I am not capable of and what is just plain stupid to attempt and this falls under the later.
Anyone who was in the Navy remembers, "The Deadly Shipmate" and I prefer not to mess with electricity at sea or on land unless it's a simple light switch or house outlet.
Smart man!
Know what you know and know your limits. Someday I'll learn to do that..
Also, be cautious when it comes to taking electrical advice from an Internet forum.... I'm except Mike Holt's :)
38,766 PostsLatest Activity: Jan 10, 2026
