kokois1
Apr 02, 2014Explorer
50 amp cheater
I am considering purchasing a 50 amp cheater system to use when there is only a30 amp and 20 amp connection available at the site hookup. Have any of you used one? Any problems or issues I need to b...
rgatijnet1 wrote:The neutral carries the difference of the current on the 2 hot legs not the sum.
Isn't a standard 50 amp plug using a total of 100 amps on the neutral with 50 amps on each leg?
