RoyB
May 07, 2014Explorer III
Consider these DMBRUSS pictorials of a typical 50AMP setup using an RV30A-50AMP Adapter.
The RV30A-50A adapter has a wire that runs from the two hot legs to feed both 50A circuits in your trailer. Everything in your 50AMP distribution will work as before except the most current you can draw is only 30AMPS
Hope this helps...
Roy Ken
Hope this helps...
Roy Ken
