wallynm
May 07, 2014Explorer
You have received a good explanation. Remember that when on 30 amp you can have what is called a brown out because you do not have enough amps to run every thing. AC use more amps (called starting Amps) when first spinning up. On 30 amps we have problems when one one AC, micro wave, and toaster and then the second AC kicks on. Normally the pedestal breaker pops. Not much 50 amps in CN.
