theoldwizard1
Jun 12, 2021Explorer II
Overkill. The 50A to two 30A doggone would fine assuming escort goes through a fuse/breaker before the load.
The following would be much cheaper. Start with a FUSED A/C disconnect box. Wire a 50A male plug to the inlet side. Wire a 30A female to one fuse and a 20A female to the other. Install cartridge fuses in the appropriate slots.
You can always buy short extension cords with pre-molded plugs and cut off the end not being used.
