Lumpty
Feb 13, 2021Explorer
I've had, in order, a '94 E350 with an EFI 460/E4OD (245hp/410 ft-lbs, with a 4.10 rear), an '04 GMC 2500HD with the LQ4 6.0/4L80E (300hp/360 ft-lbs with 4,10's) and the current '10 chassis E450 that has a SOHC V10 and 5R110 (305hp/420 ft-lbs and a 4.56 rear).
Up to a certain weight, about 15,000 GCW, the 6.0 was definitely the snappiest, and felt the most responsive. One time I had about 1000 lbs more in the trailer, approaching 9,000 lbs, pretty much right on the chassis limit of 16,000lbs GCWR, and it was not happy. Night and day how that 1,000 lbs emasculated it. mileage was always in the 8's, maybe 9 tops.
Going back to the 460 in the 1st Class C, it was classic big block power and torque. I didn't ever tow heavy with it, at the most 5500-6000lbs and a GCE of 18,500lbs, right on the chassis rating, but the drivetrain just shrugged, never feeling stressed. Mileage though was terrible. Solo, 7-7.5, towing, 6-6.5.
So onto the current V10. Never feels as eager as the 6.0 nor as unstressed as the 460, but after 80k+ miles, I am a begrudging fan. It has pulled 9000lbs, plus the 24' Class C it's in, all-up at 20,000lbs +. Solo mileage is around 8, towing 7, and has never pulled a hill (nothing out west but has done a bunch on the Mass Pike in the Berkshires and Fancy Gap on I-77) at less than 55, with plenty of pedal left. I agree the V10 does not make V8 noises; I'd much rather listen to the 6.0 LQ4 at 4500rpm than the V10, but for hauling ability, there's no comparison. The 2V SOHC V10 has gone into thousands of Class A's, which is not something that can be said for the 6.0. As cheap as RV manufacturers are, if it was a suitable engine for heavier weights, it would have been available in the Workhorse stripped chassis when they were available, instead of the 8.1 only.
38,782 PostsLatest Activity: Sep 10, 2026
