klm
May 28, 2014Explorer
6v battery lifespan?
What is the average lifespan of 6v batteries?  What would shorten the typical lifespan?  Is there a big difference in longevity between the different types of 6v batteries?  Thanks
Groover wrote:
One thing I had noticed in my coach was that every time I plugged in or started the gen-set it would charge at 100 amps for a while. At first I assumed that the batteries were low and that the charge was really needed.
Captain Obvious wrote:X2, check for what looks like a phone jack on your converter. If it has one, just purchase an IOTA IQ4 module. That will turn the single stage IOTA into a 3 stage unit.
Some iota charger/converters can be upgraded to a 3 stage charger for only $15 bucks. It's worth checking to see if you have the magic charge port on the converter.
klm wrote:
OP here. I am a fulltimer, 99% plugged in to shore power. I have 4 6 batteries. Current bank is 3+ yes and need to be replaced. Just wondering if there is something I can do to increase longevity with the new ones? I use the profill system to keep water level topped off. Anything else? Best name brand?
