AH64ID
Aug 30, 2015Explorer
Ivylog wrote:
A.. H... What part of "we do not have C brake" do you not understand? Guess we both have the same problem as we both build boost.
F...F... D...A...
Never said I didn't understand.. Simply said you are providing small bits of information and expecting us to read between the lines. Simply put your sig says '04. '04 ISL 400's were equipped with C brakes, actually started in late '02. So either your motor isn't an '04, or an '03 build, or you don't know what you have. I'll reserve judgement.
The OP has an '03 DP so it is likely he has a C brake so that wouldn't put you in the same issues. I have decided you are suffering from a case of RCI, which is probably causing most of the aforementioned issues.
Start actually discussing or stop posting a waste of useless info. Providing just a tiny bit of details would actually make the information useful but that seems to be well beyond you.
If you only build boost on the compression brake then i would say something is awry, but I suspect you will find the boost is there regardless of brake operation or no. One has to to be able to understand and correlate the information presented to them or it's useless. Again I'll reserve judgment.
38,766 PostsLatest Activity: Jan 10, 2026
