want-a-be's avatar
want-a-be
7 Pin Connector on Winnebago
We have a 2007 Winnebago Adventure. I am getting ready to run a charge line from the RV to the toad battery. When I check the positive pin in the connector with the motor running I did not have any juice (12 volts) is there a fuse somewhere?
Thanks for any and all comments!
  • i have seen some of them with 7 pin and power not connected
  • JamesBr wrote:
    Which model number adventurer?
    This is on a model 38T
  • JimM68 wrote:
    The power line on a 7 pin should be the center conductor.
    Our fist motorhome, a 99 pace arrow, had no connection there, and I had to run a power line the length of the coach.
    #2 had 12v and a fuse for it.
    It is worth the effort to make sure the toad battery is kept charged.
    Power on a 7 way is normally connected on pin 4. The center pin is an auxiliary connector most often used for back up lights. Detailed wiring info is located at this link.
  • The power line on a 7 pin should be the center conductor.
  • Beverley&Ken wrote:
    Depending on the chassis, there is probably a fuse and/or relays under the hood/firewall area. If the previous links don't help, do not hesitate to call Winnebago Customer Service. Be sure to have your Winnebago Serial # in hand, they are extremely helpful.
    Beverley and Ken
    I called Winnebago and they said to call Workhorse, I called Workhorse and they don't have a help line any longer. I found the electric diagram but can't make head or tails of it.
  • Depending on the chassis, there is probably a fuse and/or relays under the hood/firewall area. If the previous links don't help, do not hesitate to call Winnebago Customer Service. Be sure to have your Winnebago Serial # in hand, they are extremely helpful.
    Beverley and Ken
  • Welcome to the Winnebago family – the company has excellent resources online.
    Brochure archive
    http://www.winnebagoind.com/products/previous-models/index.php
    Operator Manuals
    http://www.winnebagoind.com/resources/manuals/operatormanuals.php
    Manuals & Diagrams
    Links on the page above to
    If you go here Service Parts List with your model year and the last 5 digits of your Winnebago serial # (not the VIN, the Winnebago number) you can get a listing of all the parts used to build your specific RV
    Parts Catalog
    • Plumbing Diagrams
    • Wiring Diagrams
    • R.V. Parts and Accessories Catalog -
    • How to Identify a Motor home -
    • Sealants Callout Sheets
    • Operator Manuals
    • Paint Code Manuals
    • Audio Video Guides
    Supplier Links
    • Click here
    Service Tips:
    • Service Tips
    It's also a good idea to register you as the new owner. Link below
    http://www.winnebagoind.com/products/secondowner/index.php
