tropical36
Jan 06, 2018Explorer II
aabrennan wrote:
Our location Eastern Phoenix/-camping McDowell Park—fuel starvation problem —can’t accurate & starting difficulty-2003 Tiffin Allegro 30DA
As said, check the filter, which you may find alongside the frame rail, passenger side, amidships.
Disconnect the output and see if it spurts fuel with the ignition on and probably best to attach a pressure gauge there, as well.
Check fuel pump relay, for operation and power to the intank fuel pump, as well.
If the pump is bad and before dropping the tank, see if there's a way for going through the floor and then covering with a marine access plate for future use.
