rgatijnet1 wrote:
cmarq wrote:
You May want to check the cam position sensor on the front of the block the belt may take out the wires going to it mine did. I was able to splice them together again. If check engine light is on check for that. If you can get a helper it is easier to install with two people. Napa has the belt.
One trick I use when I changed mine is that I use a ratchet strap to hold the breaker bar to relieve tension on the belt so that I can use both hands to position the belt. While under the coach on I-80 in Iowa, with traffic whizzing by, I found I could change the belt in about 10 minutes. :B
Not sure what you have there, but I can do it all from the top by myself and remain inside in comfort.
The first one I changed out, started going bad, so I replaced it with NAPA's best and so far, so good. I also have the OEM original on board at 8yrs old and 46K miles on it.
