drifterpilot
Jun 23, 2018Explorer
Update:
To be on the safe side, I had the Engine Check Light read by a garage. Code P 1518 is when the Engine Control Module (ECM) has detected a loss of data or invalid data from the Throttle Actuator Control (TAC).
From the Internet;
“The Throttle Actuator Control (TAC) module contains data which is essential for proper TAC operation. The TAC module continuously test the integrity of this data. When the TAC module is unable to write or read data to and from random access memory (RAM), or the TAC module is unable to correctly read data from the flash memory or and internal TAC module processor fault is detected and the Diagnostic Trouble Code (DTC) is set.”
Everything appears to be back to normal and I am traveling, so not pursuing anything else right now. But I have ordered the following scanner for future peace of mind in the case of another occurrence.
FOXWELL NT301 Car Obd2 Code Scanner.
I shall have it in a couple of days.
Thanks for all your inputs.
From the Internet;
