carringb
Oct 12, 2015Explorer
Weight distribution will put less bending stress on the frame extensions, and apply more shear load, which the frame is much stronger than under than simple bending. WD had few downsides, as long as it's not over tightened. You are so close to not needing it, you may be a good candidate for the Anderson hitch. It rides the best, is silent, and hooks up easily (and takes way less space in storage). It just doesn't distribute as much weight as other hitches, but for you I think that's OK.
38,778 PostsLatest Activity: Jun 10, 2026
