carringb
Oct 12, 2015Explorer
LSVLance wrote:
That Anderson hitch looks pretty interesting, looks like you have to make sure you back up to the trailer at the same angle you did when you dropped it off though or it becomes a pain in the butt to straighten the triangle plate.
There's a couple workarounds: use a mallet to smack the bottom of the hitch to loosen the grip of the friction cone, so you can spin it by hand. Or... Hook up the loose chain first, pull forward to snug up the loose chain, then hook up the other side.
Note: there's another problem that may actually a bigger concern... It loads the pawl in the coupler, and some coupler designs don't like this. Anderson has a list of incompatible couplers.
38,778 PostsLatest Activity: Jun 10, 2026
