Bruce_Brown
May 04, 2015Moderator
msmith1199 wrote:
How do you know a rubber roof wouldn't have blown off?
Have you ever in your entire life seen one blow off? Neither have I. :W
Having worked on both, the fiberglass style in question, and more than a few rubber roofs, I can assure you the rubber roof won't blow off. While a rubber roof certainly has it's own set of issues, blowing off isn't one of them. A typical rubber roof is both glued and mechanically fastened. Even if you cut a section away from the mechanical fastening part at best all it would do is flap a little. They just aren't rigid enough to completely peel.
