enblethen
Jul 06, 2021Nomad
Some of the early P-30 based MHs had an electric pump in the big tank and relied on the mechanical pump to suck out of the small tank.
The solenoid gas valve or switch assembly could be issue.
If you have the dual tanks check to see if your small front tank has an electric pump. If it does not, you need one.
