2gypsies1
May 07, 2018Explorer III
Yes they are and many do it.... no other way to get to Flagstaff.
89 is almost flat to Page, AZ. After leaving Page you'll see a truck sign to "check brakes & to use lower gear next 5 miles". The grade down with be a 6% for about 4 miles. There's a runaway truck ramp.
89A - From Fredonia you'll have a easy uphill. At Jacob Lake you'll be in a lovely pine forest. (no lake here, by the way) Then you have a descent down to desert. The descent is around 10 miles of 5-6% with curves. It's a good road. Before the descent there's an extremely wide scenic pull-off on the right. Stop and take in the view! We've done both in both directions. No problem with our 40' motorhome.
38,768 PostsLatest Activity: Jan 26, 2021
