Miked9606
Jun 08, 2018Explorer
enblethen wrote:
Did you find the battery control center? normally driver's side under the hood.
Check for voltage at battery disconnect for chassis and follow the power. There maybe a tripped circuit breaker.
I’m new to rv and learning as much as possible. Did find control center have cover off. Battery disconnect is that the same as the solenoids in bat control center? Can I check power there by connecting meter to both big post?
